ECU readout's and aftermarket computers/display's.
TheSubaruJunkie
Post by TheSubaruJunkie »
This EJ22T is the 1st car i've had that has a real computer that actually does more than adjust the choke on a carburator. Im wondering if there's a way I can connect an aux. computer or display that will show me actual RPM, MPH, Fuel Mixture, and anything else I might want to know about my car.... timing, etc...
Since my car is canadian, i think this might help me decipher all the KM/h and Metric readings in my dash, also, i think it'd be just plain COOL!
Heh
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
It can be done, but I don't think anyone (other than Subaru) has made such a device publicly available. I use my laptop that way in my car, but I don't really have all the info yet on how to do it on any arbitrary Legacy. If I get it all sorted out I'll let you know. :)
TheSubaruJunkie
Yeah, sooner or later i'd like to get it all tapped into a laptop where i can record the data and examine it.
-Brian
1986 Toyota 4Runner
It's not high-throughput, though... You get several samples per second, and can only read one channel at a time.
Cpt_chood
Post by Cpt_chood »
i don't know if this will help in your quest, but you might consider a Apex-i AVC-R, my friends brother has one in his accord, and i have seen them in legacy's also, it alows you to monitor boost, speed, RPMs, Injector duty, Solenoid duty and throttle position, that i know of, but hey it's an option, check it out and see what you think.
DLC
Post by DLC »
I'll second the AVC-R, and combined with an S-AFC, you'd get fuel readings as well. They have a timing controller, but i've never seen one. For mixture you'd just have to set up a normal A/F gauge.
The Apex-i stuff is pricey, but it's very nice. They work by intercepting the signals from the sensors to the ECU, so you're not limited by the processing power of the ECU, just the capabilities of the device.
Legacy Central
91White-T
Post by 91White-T »
I thought our ECU's learned around AFC's, no?
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Brat4by4
Stratified
Post by Brat4by4 »
Eventually, yes. This happens on GC8's. So I assume it would be the same on ours.
