2nd gear synchro woes
mTk
no title
Post by mTk »
Just as the topic sounds, my 2nd gear synchro is on it's way out. Grinds when i upshift, grinds when i downshift, if i get it at jsut the right RPMs it's OK.
There are a few thing i am going to try before i do a rebuild or replace. I'll post them in this thread, as the sticky is muddled with other stuff.
MK
1992 BC672 AWD 5MT
Sounds like a reason to learn double declutching and heel and toe :lol:
mTk
no title
Post by mTk »
1st attempt: Switched to 40w Castrol GTX (yes i know it's much lower visc than the recommended 75w90)
So far, excellent, the grinding is nearly gone under all condtitions.
MK
1992 BC672 AWD 5MT
mTk
no title
Post by mTk »
Went ahead and tried 75w90 Royal purple gear oil today.
Problem is worse, 2nd gear synchro will grind under high rpm shifts.
Time to switch back to 40w
MK
1992 BC672 AWD 5MT
NICO
Post by NICO »
mtk you got the right idea, i no what is going on, the trannys are very very pickie about what oil gos in. they are really really strong, but if you put the WRONG OIL in then they will blow up, or grind, or not even go in. i whent threw five trannys just to figger this out how to stop it, i like the factory stuff and i have to change it 3 times a year no more busted gears for me.
keep testing mtk you will find the right oil for it.
I think I said this in another thread, but 40W motor oil is similar in viscosity to 75W90 gear oil.
Have you tried using Castrol gear oil?
georryan
Post by georryan »
So Castrol 40w would be similar to a castrol 75w90 gear oil?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
DLC
Post by DLC »
Gear and motor oil weights are measured differently, for some reason, so i think vrg3 is onto something. It might be some property of the motor oil that makes the synchros less picky.
Legacy Central
mTk
no title
Post by mTk »
http://www.irvingoilco.com/images/viscosity.gif
posted for the lazy.
*hopefully* this weekend i can change it again, i'm going to try to find synthetic 40w or 30w motor oil.
MK
1992 BC672 AWD 5MT
You're pretty determined not to use gear oil? I'm a little worried about your front differential.
heelhooker
Post by heelhooker »
redline mtl 70w-80 is working quite well for me. I was getting grinding going into 2nd gear before switching oils.
Paisan
Post by Paisan »
Excellent thread. I have 2nd gear grinding in my '94 Legacy as well. I switched to Amsoil 75-90, going to try Redline now and see if that helps, last resort will be the subaru stuff.
-mike
