Howdy y'all,
I'm a Ford mechanic, girlfriend has a 2.2 Impreza. OBDII tells me the TPS is bad. Can anyone tell me how to test this on this vehicle,what the voltages should be? found a good description online for the 91-94 Impreza's, is itthe same?
Thanks,
Derek
96 2.2 TPS
Your best bet is http://forums.nasioc.com/forums
That is the North American Subaru Impreza Owners Club forums.
Id first just take the connection off and check for resistance (with the car off). Find the one that sweeps as throttle positon changes and check for a smooth change.
