MBC install ?
james_gt
MBC install ?
Post by james_gt »
I just got one of these, I was wondering if I am supposed to completly bypass the stock boost control solenoid. I woul like some pictures of setups. Thanks
james
mTk
no title
Post by mTk »
I installed mine on wednesday night, i bypassed the stock solenoid. Took the hoses of from teh stock solenoid and put them onto the MBC.
MK
1992 BC672 AWD 5MT
boostjunkie
Post by boostjunkie »
Go here:
http://www.legacycentral.org/library/hbc.htm
Instructions should be similar to your boost controller, as long as it's a MBC.
Woah, woah, no! Don't follow the instructions there; they tell you to use the intake manifold as a boost source rather than the compressor outlet. Search instead on here.
In a nutshell, though -- bypass the stock solenoid. Disconnect the sideways fittings (and cap off those nipples) and put your controller in between the hoses you pulled. It'd probably be better, though, to replace those hoses with shorter simpler ones.
LegacyT
Post by LegacyT »
Is there any way to stopnthe stock boost solenoid from clicking when you bypass it? Can I just disconnect the electrical connector?
Mark,
If you disconnect it the ECU will throw a trouble code and go into a form of limp mode. If you're really intent on removing it you could replace it with a resistor so the ECU still sees a load. 470K 1/2-watt worked on my car.
But it's probably fine just to leave it alone... It's not gonna click any more or less than it used to.
LegacyT
Post by LegacyT »
strange thing is, when on stock boost my boost solenoid never clicked, never. As soon as I installed a mbc it clicks like craazy right above idle, its so loud and actually gets annoying, so I'd like it to stop it.
Mark,
It's actually doing the same thing as before, except the sound of the clicking isn't traveling down the vacuum hoses.
Did you cap off the fittings on the solenoid? If you haven't done that yet, that should muffle most of the sound.
LegacyT
Post by LegacyT »
yup I capped both outlets with vacuum line caps. the clicking is loud as hell. I returned it to stock before for a test run and the clicking completely dissapeared, I tried as hard as I could try to hear it clicking, nothing. Then I reinstalled my mbc and it clicks again, argh.
Mark,
TurboLegacy
Post by TurboLegacy »
to install the mbc all i have to do is put it inplace of the boost controll solenoid. just put the two hoses that used to be on the solenoid and put it on the mbc?, is it that easy.
92 legacy turbo 5spd fwd-12 psi, tm intercooler bov, walbro 255.
81 chevy malibu- 400 sb, holley 600, edelbrock rpm, hooker headers, lunati voodoo cam,4spd muncie, 3:73 posi,monte c. swivel buckets, corvette rally wheels
LegacyT
Post by LegacyT »
yup just remember the one from the turbo is the goes into the boost source inlet on the mbc. And the line to the wastegate goes to the other nipple on the mbc. Don't mix the two up.
Mark,
TurboLegacy
can i trust a boost controller from ebay for $20?
TurboLegacy
on ebay there is a " best maual boost controller" for 9.79 buy it now, should i go for it?, looks very similar to a hallman. if any body looks at it, which end goes to which hose from the boost solenoid.
THAWA
Post by THAWA »
Why not just make your own for less than that and save on shipping too?
LegacyT
Post by LegacyT »
if your gonna buy an mbc buy a ball and spring type, not a bleed valve. Their much less accurate and you boost changes with the temperature, it becomes very annoying, trying to keep a constant level of boost day to day. All hallman mbc's are ball and spring and have a very good reputation.
Mark,
TurboLegacy
mbc
i just bought one of the mbcs from ebay for 9.79 and 5.99 shipping, it is a ball and spring type, ill try it and tell you guys how it works. it wont be that big of a loss if it doesnt work right.
TurboLegacy
LegacyT wrote:yup just remember the one from the turbo is the goes into the boost source inlet on the mbc. And the line to the wastegate goes to the other nipple on the mbc. Don't mix the two up.
Mark,
what would happen if the two accidentally got mixed up?
If the design of the controller is like that of most ball-and-spring MBCs, you'll get boost limited only by how much exhaust gas your engine can pump out. On a stock Legacy Turbo, that means it'll climb scarily fast to over 20 psi.
TurboLegacy
what about the 13psi fuel cut?
TurboLegacy
i installed my mbc today. i dont have a boost gauge, but i started at really low boost and turned it very little each run untill it was only a little faster than stock. i now have full boost up to redline. i think i am running around 9.5-10. i wont turn it up anymore till i get the boost gauge and an i/c.
