Strange chirping noise behind centre dash????
philhustler
Post by philhustler »
I have noticed (when i turn the system down) a bizzare chirping squelching type of noise which appears to be coming from directly behind the stereo unit. Its a 92 Legacy wagon.
It sound like water getting forced through a small pipe or something. Airconditioning?
There is no leaks or damage being caused as far as i can tell it has been going on for about 5 months. All the electrics and air con work fine, i just cant figure it out.
Let me know if youve heard something similar.
ciper
Post by ciper »
The most common behind dash noises are bad speedo cable connections and coolant that needs burped/filled.
If that helps any.
QuickDrive
Lurker-King
Post by QuickDrive »
I hear a strange chirping behind my dash too,
when I'm whomping the gas pedal and leaving civics in my dust, hahaah
R I P-------- 91 Turbo 4EAT --------R I P
Mine makes an odd chirp on occasion also. Mine has something to do with the vent position control. It doesn't cause a problem so I leave it alone.
WhiteLegTurbo
Post by WhiteLegTurbo »
evolutionmovement wrote:Mine makes an odd chirp on occasion also. Mine has something to do with the vent position control. It doesn't cause a problem so I leave it alone.
i have the same chirping noise and it ocassionally stops but i noticed that when its not stopped my vents dont work nearly as well as they would when its stopped.
1994 Subaru Legacy 2.2 turbocharged AWD
luckylouie
Post by luckylouie »
I had a similar problem on another car (89 Toyota PU 4x4).
It turned out to be the speedometer cable.
The noise was more noticeable on cold weather (the speed needle would wiggle a little).
I filled a syringe with WD40 and injected in the cable from below the dashboard in both directions.
It worked like a charm!
Louie
Post by BAC5.2 »
I have a chirp that only happens at ~2300 or so RPM, and under a moderate throttle. I figure it's a heat sheild, which will be fixed with the exhaust install.
