External engine oil cooler
When i had a 4eat i installed an external tube & fin atf cooler. I'd like to use the same cooler for engine oil now that i have no 4eat. I can probably find a sandwich adapter for between the block and filter that i can run hose from.
My questions are, will the same hoses i used for the atf work w/ engine oil? I'm guessing that the engine oil will be under quite a bit more pressure than the atf was.
Additionally, what is the thread size for the oil filter?
MK
MK
1992 BC672 AWD 5MT
1) I don't see why hoses that stand up to ATF wouldn't stand up to motor oil. Isn't ATF under high pressure too? I mean, it does operate hydraulic circuits.
2) I believe the filter threads are M20x1.5mm.
3) Someone else who knows better should offer their insight too, but I think the fittings on the radiator's ATF cooler are really small. I don't think it'd work that well for motor oil.
4) Why not use an OEM oil/water heat exchanger? Unless you're making a lot of heat, engine coolant should be able to carry it away. You get other benefits too: the engine warms up quicker, you don't have hoses running all over the place, and the oil changes become easier because the oil filter is easier to reach.
oil cooler cores can be had for $40 or so from www.summitracing.com
If the hose bore on the ATF cooler is much smaller than the main oil lines then youll probably lose oil pressure all through the system due to the restriction but the connectors will almost definately handle the pressure, hydraulic hoses of any sort are way OTT for engine oil pressures.
Also, why are you adding an extra cooler and where are you planning on putting it? If youve got a turbo model then it may be worth running it inline with the turbos oil feed, preferably before the turbo to keep it nice and cool.
If only I hadnt bought the bike, this would feel fast :P
It can be hard to find good high-temperature oil-resistant hose. We were looking when plumbing my brother's turbo oil drain line. I'm sure you can find expensive Teflon hose that's spec'd right, but we're poor so we ended up using some hose that's only rated up to something like 257 degrees F. That was the highest we could find.
Then again, the hoses that came with his oil filter relocation kit seemed to be made of ordinary rubber (no Teflon sheaths or anything), so there may be some rubber formulations out there that would be fine...
Quite what temperatures are you expecting here, the hottest I ever saw it get on my old golf was 105degrees. I accept on a turbo car it may get a bit hotter but much hotter and the engine will be scrap anyway and the coolant will all boil off surely. Oh and whoever said hot oil will eat through any hose eventually, yeah your right, but thats why you maintain your car lol
It all depends on where you're dealing with the oil... The oil drain line off the turbo probably has the hottest oil you'll find on the car. The oil that's fed to the filter is probably fairly close to the engine's operating temperature, roughly 100 degrees Celsius.
Someone please correct me if I get this wrong, but:
Coolant (both sides): 12mm banjo. I don't know the threading on the banjo bolt but I'd guess M12x1.25mm or M12x1.50mm.
Oil feed (head side): 12mm banjo also, same as coolant lines.
Oil feed (turbo side: 10mm banjo, probably M10x1.0mm or M10x1.25mm threads.
Oil drain: 2-bolt flange with gasket. The stock tube that attaches there has an outer diameter of 15mm.
on a semi related note aren't our wheel studs 12x1.25?
I could just see someone with spline drives or an STi knob on their turbo
