WILL IT FIT? Stock WRX Header-> '91 Legacy Turbo
Posted: Thu Apr 08, 2004 3:57 am
by BoostAddict
Hi,
I'd like to know if a stock '02 WRX Header would fit on my '91 Legacy Turbo. Would such a header give me any performance increase over the stock Turbo header, which I have now? I'm also planning on changing he exhaust to a 3" and I'd like to know if it'd be worth to change the header to a WRX one...
Thanks in advance,
P.
Posted: Thu Apr 08, 2004 4:01 am
by THAWA
I'm assuming you mean the uppipe and crosspipe? I dont know if they will fit up to the turbo or not but I wouldn't suggest using it over the stock one. WRX uppipe has a cat in it whereas yours doesnt.
Posted: Thu Apr 08, 2004 5:18 am
by BoostAddict
So would the WRX header flow worse than the stock Legacy turbo header?
Which header will have a larger diameter?
Posted: Thu Apr 08, 2004 2:04 pm
by boostjunkie
I was under the assumption that they are the same header *shrug*
Posted: Thu Apr 08, 2004 2:43 pm
vrg3 wrote:I do know that the driver side manifold is actually the same part number for WRXes and turbo Legacies.
So the driver side won't flow more. The passenger side probably also flows exactly the same, too; it just has a bung for an oxygen sensor.
Posted: Thu Apr 08, 2004 2:53 pm
by BoostAddict
Thanks a lot for the answers!
In that case, I won't get the WRX header. I'll just leave my stock one and focus on the exhaust.
Does anyone know of any used bellmouth or divorced 2.5" - 3" downpipes for sale (on the board?).
The $150 for the DP on eBay is 'kinda pricey for me...
(considering that my WHOLE car didn't cost me much more than that
P.
Posted: Fri Apr 09, 2004 2:37 am
by BAC5.2
If you want to play, you have to pay. Exhaust parts, quality ones at least, are expensive.
I would save up for the full C.E.S kit. Almost 1/3 of the total cost of my car, but I'm still doing it
