What does this nipple connect to? And what flows through it?
Opie
Post by Opie »
On the top of the EJ22T block, directly behind where it is stamped EJ22 what purpose does the brass nipple serve?
I believe it is for the oil blow-by from the valve covers but just wanted to be sure!
Thanks!
2000 Legacy B4 RSK, 2013 BRZ-Track car, 2021 Forester Sport
Yes, it's for crankcase ventilation. There's a black plastic tee (with really long sides) that connects that fitting to one fitting on each valve cover. You can see it in the PCV diagram here:
http://www.graphics.cornell.edu/~v/vacuum/
I don't know whether fumes flow into it or out of it though.
Opie
Post by Opie »
Thanks! :D
THAWA
Post by THAWA »
I still cant get over how orange the inside is!
Actually, that's also a great picture to show where the oil gallery plug is on the rear. That would be helpful for anyone trying to install an oil pressure gauge or something.
THAWA
Post by THAWA »
and where the knock sensor mounts :)
mikec
Post by mikec »
The oil gallery plug is just to the right of the crankcase breather, correct?
THAWA
Post by THAWA »
right, but whats that other thing about midway through the engine on the driver side for? another oil plug?
Mike - Right.
THAWA - Hmm, I dunno... It does look like another oil plug. I bet that's what it is... But it's probably impossible to access once the water manifold and intake manifold are attached.
Opie
Post by Opie »
THAWA wrote:right, but whats that other thing about midway through the engine on the driver side for? another oil plug?
Yes, it is also an oil plug, as are the 14mm bolts (one on each block half) that give access directly to the oil passages that feed the heads.
THAWA
Post by THAWA »
I was going to ask about those next :)
