Dipstick?
import_freak
Dipstick?
I was looking in the engine bay of the sube the other day, and noticed a yellow dipstick opposite the engine of the tranny dipstick. It's probably about 6 inches long or so. Just curious what's it for?
93 legacy turbo sedan
00 jeep wrangler
00 jeep wrangler
There are two dipsticks connected to the automatic transmission: one for the ATF and one for the gear oil in the differential. I'm not sure which is which since I'm not that familiar with the automatics, but you could figure it out just by pulling the dipstick out and looking at the color of the fluid (usually ATF is red and gear oil is gold).
import_freak
The front diff dipstick is on the passanger side, and the ATF dipstick is on the driver side. Also the ATF stick says ATF (DEXRON II) on it.
probably only on the 92-94 models.THAWA wrote:The front diff dipstick is on the passanger side, and the ATF dipstick is on the driver side. Also the ATF stick says ATF (DEXRON II) on it.
I know my 90 is just metal with a hook.....on both sides.....which is probably why people confuse them all the time.
I know for a fact my dipstick says this, maybe your sticker was peeled off?
both mine are wire hooked metal things......
same with mine, there's a lil silver sticker on the boot(i guess) of the atf stick.
