At first i had some ecu codes, knock, solenoid and MAF.
I changed the knock sensor solenoid purge and the MAF went away after those were changed. I am hoping that still isnt the problem. I was ripped off at a salvage yard were i purchased a MAF for an AT which they would not take back and assured me it would work even after i repeatedly told them it was not for a MT. Ive also changed the FPR and fuel pump. Still stalls. A while back i had an exhaust leak. after i got it fixed the car seemed to stablize quite a bit but not fully. The leak has returned possibly this is causing the problem to persisit but i find it strange for an exhaust leak to cause the car to totally stall. Any ideas would be appreciated. If you live in the NY area come on by and check it out for me
Konrad
