wind noise from leaky front door seals - adjustment possible
Posted: Tue Apr 20, 2004 5:05 am
by mp
Has anyone successfully fixed air leaks from the seals around the front doors? My drivers door seal really whistles once I am going over 40mph.
I wonder if there is any window adjustment possible
Has anyone replaced the seals? Probably too expensive.
thanks
Posted: Tue Apr 20, 2004 6:38 am
by evolutionmovement
1/4" polyethylene pneumatic tubing I stole from work between the folds of the weatherstripping works well for me. I did the leading edge from the side view to a little around the corner at the top front of the window. Has worked well for years. Watch out that it stays there, though - for some reason I've had windshield-replacement idiots remove them for me and not replace them.
Posted: Tue Apr 20, 2004 1:46 pm
by boostjunkie
I think Legacy777 just said to roll out the weather stripping to make a better seal.
Posted: Tue Apr 20, 2004 7:35 pm
by BAC5.2
I did what Steve did on my 95. Worked great.
Posted: Wed Apr 21, 2004 2:53 pm
I just used some 8 gauge ground wire behind the weather stripping to help seal.....it works for the most part.
Posted: Wed Apr 21, 2004 3:29 pm
by petridish38
There is a way to adjust the "preload" on the glass so it seals better... The Haynes manual describes it, and i'm not sure if the FSM does or not......
Andrew
Posted: Wed Apr 21, 2004 4:58 pm
by nsantos23
http://bbs.legacycentral.org/viewtopic.php?t=16143
Take a look there, try that and let me know if it works for you, it surely worked for me
Neo
