Turbo Woes
Turbo Woes
I recently installed Vrg's FCD and re-routed my MBC to where I can access it more readily. I went for a test drive around the block and was tuning my MBC to run 13psi to see if it worked. Well, moral of the story... i turned the MBC all the way up and all I get it 9 psi tops. What gives?
98 LGT
Seems like the stock waste gate solenoid is controlling things. Did you bypass the stock solenoid? Or did you run inline with the stock solenoid?
Matt Monson
- quasi-mod-o
[quote="BAC5.2"]Seems like the stock waste gate solenoid is controlling things. quote]
The only issue with that theory is our cars run 11psi up here because of the altitude, but that doesn't mean that the solenoid isn't involved...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
legacy92ej22t
But our wastegate actuators are 6 psi right? So if he is running wastegate boost then he would have around 6 psi at sea level. So at higher elevations 9 psi might be about right.
The VRG FCD doesn't do anything to control boost, it just alters (clamps) the signal that goes to the ECU from the pressure sensor. So I would think something is wrong with the MBC setup.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Uh, ya, true. I was trying to tie in the atmospheric/manifold pressure pressure sensor signal with just manifold pressure.vrg3 wrote:Left up to the wastegate actuator, boost will always be about 6 psi gauge.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
That sounds like your problem. Buying a cheap no-name off of E-Bay.
Invest in a Joe-P MBC and install it correctly.
I can't agree at all. Spending that kind of money on something so simple is just silly.BAC5.2 wrote:That sounds like your problem. Buying a cheap no-name off of E-Bay.
I'd rather spend 40 bucks on something that is designed to work than 15 bucks on something that some jackass just randomly slapped together.
I agree with THAWA that an expensive MBC isn't worth it.
The Joe P boost controller isn't anything special. You can build the same thing yourself with pieces from the hardware store and less than an hour of work.
I also wouldn't buy one on eBay for the same reason.
But anyway... the type of boost controller isn't $J-MoNeY-$'s problem; no boost controller you can buy can force boost below the level determined by the wastegate spring.
Care to explain to me why spending nearly 4 times as much(depending on if you've got spare parts sitting around) for something that does the exact same thing and will perform at the exact same level automatically makes something better? Also don't buy it form some random jackass, make it yourself.
EDIT: I just looked at joepmbc.com That is exactly like an mbc you would make. What makes you think some random jackass didn't put together your 45 dollar mbc?
People buy STi parts, don't they?
You can make or get cheaper most things from STi, yet people still buy them.
Same goes for almost any major manufacturer.
People will spend $50 on a gauge pod instead of just screwing a gauge to a home made bracket.
Jiffy Lube is the perfect response to what you asked. Changing your oil takes 20 minutes and costs less than $15, yet people are willing to spend twice as much to have Jiffy Lube do it.
Jiffy Lube is a multimillion dollar company. It costs $30 for an oil change. And it takes longer to go to Jiffy Lube than to change your own oil.
I agree, and everything you said falls under what I'm saying. But you still didn't answer my question.
Because it's easier to buy than to make. ESPICALLY if you buy it used.
If you can buy a used Joe-P MBC for $20 shipped, it's easier than building your own for $15 + gas.
j money, could you get more boost when you didnt have that fcd in?
how does the fcd work? is it a circit type where you spliced it in to the factory fcd? if so that could be your problem.
