First, the car was running great, but I soon fell victim to the common hesitation problem, so I figured I should replace the knock sensor. Took out the old one and it was cracked (big surprise
signal from ECU harness to connector = positive
shield from ECU harness to shield at connector = positive
shield at connector to negative battery terminal = positive
shield at knock sensor to negative battery terminal = positive
signal from ECU harness to shield at ECU harness = negative
signal at knock sensor to shield at knock sensor = negative
The only things that I don't know how to test are the actual funtionality of the sensor, and the pins on the actual ECU. I believe that the B56.4 pinout is good because there is continuity to ground at the shield at the connector when the ECU harness is plugged in, but I don't know what to look for from the signal wire with the harness in the ECU. And as far as the functionality of the sensor, I've been led to believe that it creates a voltage or waveform, much like a dynamic microphone, and the ECU will initiate timing retard when the input signal peaks too high. I have no idea how to test if the knock sensor is emitting this waveform or not. I only know that it's not shorted within itself, and that it is brand spanking new, so I would hope that it is in working order.
Other factors include:
- Intermittant Code 35: canister purge solenoid, but who cares.
- At this point I can only torque the knock sensor bolt down to 13ft/lbs (not the Haynes recommened 15ft/lbs.) because I slightly stripped the block
- During the first intall of the dealer purchased knock sensor, I also built and installed vrg3's do-it-yourself FCD, but since then I have taken it back out. For those that don't know, the FCD is tapped into a completely different harness on the ECU, so I see no coorelation. Nonetheless, it's out now.
- I have repeatedly reset the ECU by both the negative battery terminal disconnect method, and the D-Check/Clear Memory method using the green connector and such.
Help!
-mike
