Caliper Locking
Posted: Mon May 03, 2004 11:05 pm
by nsantos23
Hey guys,
my 94 SS driver's side caliper is locking into one position and it is burning pads, i have already taken it apart cleaned it and lubed it and still doing the same thing, any suggestions? or if i need a new caliper do you know where i can get one other than the dealer?
thanks
Neo
Posted: Mon May 03, 2004 11:16 pm
by Brat4by4
Posted: Mon May 03, 2004 11:28 pm
by Brat4by4
Actually, I change my mind. I would try to find a used front WRX Caliper/bracket set. Everyone and their mother does a front brake upgrade on their WRX so there are lots of low mile stockers laying around. The increase in braking power is superb.
Posted: Tue May 04, 2004 2:17 am
How did you take it apart, clean it, and lube it?
Did you verify that the caliper can slide on the guide and lock pins? A seized guide pin sounds like the most likely culprit.
Posted: Tue May 04, 2004 6:55 am
by eastbaysubaru
Yup. That's exactly what happened to me three years ago. My passenger side guide pin was seizing and causing the pads to wear down extremely quickly.
-Brian
