Can I switch the position of Pistons in an EJ22T?
Posted: Fri May 07, 2004 1:24 am
I am rebuilding an old EJ22T I have.
When I pulled out the pistons one had a significant amount more scratching on the side then the others. I was told I should replace it.
I have some used pistons out of another EJ22T but unfortunately the scratching on the one I need is worse then the one I allready have.
So my question is, can I put a piston in the Left that is labeled Right. I see each piston has a label on it so I am not sure how that works. I suspect that perhaps it is just so the orientation of the piston isn't confused and thats it.
I noticed that the piston tops do have very slight valve cutouts in them and they are different exhuast to intake. So other than putting the Right hand piston in on the left upside down should I be aware of anything?
-Thanks a lot
-Mark
-Thanks a lot
-Mark
