Subaru Legacy AWD Shudder/Vibration
kairish72
Post by kairish72 »
I have a 1995 Subaru Legacy AWD L Sedan, that I am getting a shudder vibration coming from the right side rear wheel. I am in the process of getting estimates of what it might be, the first place is saying it's the clutch in the transmission and our quoting 2000-2800 depending on parts needed.
The shudder only happens when the car is first moving forward, then the shudder disappears, and it does not happen in reverse. It is not consistently happening all of the time, and can go for a day or two without making any noise. It is more apparent on turning right as well.
Any thoughts .....
DLC
Post by DLC »
Read this:
http://legacycentral.org/library/torquebind.htm
It's either the transmission, if yours is an auto, a wheel bearing, or perhaps an axle issue.
Legacy Central
Post by BAC5.2 »
Wheel bearing is likely.
kairish72
Post by kairish72 »
would this also produce debris and brass shavings in the auto-tran pan?
Post by BAC5.2 »
oh, no wheel bearings wouldn't do that, lol.
kairish72
Post by kairish72 »
then I'm looking at the transmission then? huh
1995 Subaru Legacy L Sedan AWD
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
dang. that's gonna be expensive. sorry. :(
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
kairish72
Post by kairish72 »
Since I'm not a car geek at all, can someone explain the clutch part of the Automatic transmission, which what they are saying needs to be replaced.
THAWA
Post by THAWA »
The clutch pack is for shifting. different clutches engange and disengage depending on what is going on.
you should check out: http://auto.howstuffworks.com/automatic ... ission.htm
