Anybody got a picture of the clutch pedal spring setup?
Because I'm confused as all hell
yes it does, but now I'm even more confused. I dunno where the washers or those pins go :\
also when I press the pedal in it slams to the depressed posistion and the spring holds it there. Maybe the early impreza's have a different system from the legacy's. The clutch switch looks to be in a different place. :\
I dunno it's just two small washers, taht look as if they fit over the springs end, and two pin like things. Might be considered clips. They look like the lil clip type thingy on the brake clevis pin, but straight :\
Depends on hydro/cable clutch (for spring location etc iirc). As far as return, on the hydro atleast the pedal does stay depressed. The clutch fork pushes back and fluid pressure makes it return (for the most part)
MK
MK
1992 BC672 AWD 5MT
