Help!
Help!
When turning, I get a whum-whum-whum-whum noise coming from the wheel on the outside of the turn. The noise is definatly worse at higher speeds or when accelerating, and is slighty different depending on which direction you turn. I also have a fair amount of steering wheel vibration when on the highway.
Cv joints arn't leaking any grease. I've also taken a look under the car and havn't seen anything that's visibly rubbing anywhere.
What the F@#k is wrong with my front end? Rotors? Brakes? something I havn't though of? Suggestions please!
- quasi-mod-o
yeah it actually sounds a bit like a loose lug
I've checked them many times though
I'm going to a rally soon, need to get this sorted =(
I may be forced to pay a shop to look at it and hope they don't screw me over.
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
SOLD :(
99 impreza RS
Have you had a loose lug before?
Sometimes a loose lug nut can slowly round out the lug hole in the wheel, which can make it impossible to properly tighten the lug nut. This is more likely with alloy wheels, since the steel of the lug stud is harder than the aluminum of the wheel.
I had to replace a steel wheel when Detroit roads loosened one up. I was doing somewhere around 110 on the Logde FWY when I heard this banging from the rear. What the hell is that? Didn't stop me from going to my ex's college 10 miles away, I'll tell you h-what. Trying to find Subaru parts in Detroit then, I might as well have been asking for parts to a Trabant.
yeah, ive had a loose lug or two.
Just rotated the wheels front-to-back and used a little hammer to tap the brake dust shields back a bit just to make sure there's lots of clearance. Will take it for a spin and see...
SOLD :(
99 impreza RS
SOLD :(
99 impreza RS
Nope, exactly the same =(
Is it possible the tierods are pushing on the dust shields and making them rub on the rotors?
I donno, I am totally at a loss.
SOLD :(
99 impreza RS
SOLD :(
99 impreza RS
Hrm, not being terribly well-versed in the operation of the drivetrain, I usually avoid applying force to any of the wheels. Spinning the fronts with the transmission in neutral and the rears on the ground should be fine?
SOLD :(
99 impreza RS
SOLD :(
99 impreza RS
You have a 5MT, right?
As long as you spin the front wheels in opposite directions (you'll notice that turning one wheel will automatically turn the other in the opposite direction anyway), you'll send no torque into the center differential.
If you have a 4EAT, the rear wheels are actually completely disconnected from the fronts when the car is off.
To be completely safe, chock the rear wheels both in front of and behind the wheels, and stay to the side of (not underneath) the vehicle when you first rotate the wheels. Then, when you're confident you're not going to force the car to drive off its jackstands, you can get under the car and try to find the source of the noise. If the car's properly supported by jackstands a friend should be able to get inside to turn the steering wheel.
Yeah it's a 5mt. I'll give that a try when I get home. If I cant track it down, is there any reason why putting the car on four jacks and spinning the wheels up to speed with the engine is a bad idea?
SOLD :(
99 impreza RS
SOLD :(
99 impreza RS
If you mean four jackstands, there should be no problem as long as you're gentle with the engine (you don't want it rocking on its mounts) and you make sure nothing touches any of the wheels.
You shouldn't need to use the throttle, I don't think... idle in 4th or 5th gear ought to be fast enough.
Yeah.
When my brother was young(er) and stupid(er), he and his friend once decided to work under his friend's lowered (maybe two or three inches of ground clearance) MkIV Supra after raising it with two factory scissors jacks... Not a minute after they got out from underneath it, it fell off the jacks. It's amazing they didn't both die that night.
greg donovan
k lifted the car, spun the wheels..no noise =(
The speedo really does go past 220km/hr tho =D
I'm taking it to my ninja mechanic to get some IC pipes TIG'd up and some skidplates made on friday, I'll get him to inspect it...
SOLD :(
99 impreza RS
SOLD :(
99 impreza RS
