search engine woes
Let us know what you think about the site and the forums and give us your suggestions on how to make them better.
Lorryb
search engine woes
Post by Lorryb »
Is there something wrong with the search engine or is it just me as usual? I tried to search for "antenna" (I want to know how to remove one) but nothing was found. Peculiar, if you look in the Parts Shed there is a post with the word "Antenna" in the subject line and I know I have read other posts that mention antenna. 0
91 Legacy LS AWD Wagon
mTk
no title
Post by mTk »
it does have problems, especially when searching for a term posted by a specific user.
MK
1992 BC672 AWD 5MT
I just searched for antenna and found 74 matches.
I however chose the "search for all" button rather then search for any. Either way, it's still going to show up 74 matches.
Are you still not getting any results?
The search engine on this site is pretty good, if you want to narrow your search a little, it may take a little tweaking.
Lorryb
Post by Lorryb »
Well I'll be dipped, after I read Josh's post, I redid my search, same variables exactlyh, lo and behold, a virtual plethora of hits. I guess the old spider was right, if at first you don't succeed , try, try again.
Glad it worked....let us know if you have any more problems, or questions.
