New struts not the complete answer?
Lorryb
Post by Lorryb »
I just finished putting GR-2s all around my 91 Legacy AWD wagon. They are a vast improvement over my old worn out struts but I am still getting some clunking up front around the right strut. Any ideas what could be the culprit? Ball joints? tie rod ends? any other guesses?
The GR-2 s are sure nice, it has helped the droopy butt my wagon has had since I swapped out the air suspension.
91 Legacy LS AWD Wagon
Top mounts or antiroll bar bushings.
Brat4by4
Stratified
Post by Brat4by4 »
check the front sway bar endlinks. you might just want to replace them with the whiteline metal endlinks ~$50.
make sure you tightened the strut top nut all the way.
