speedo quit
speedo quit
my speedo quit the other day and is somehow linked to the ecu because it threw a code not sure what code it is. The car also started idling very low like around 200 rpm and when i take a slow corner the car stalls whats going on?
Proud owner of a 1991 Silver 5MT
Gold wrx wheels,Straight Exhaust, DNA Boost Controler 12 Psi, Ngk's, De-Snorked, Carbon fiber hood scoop in the werks
1991 White 5MT(Sold to Friend), AKA BINFORD
"KEEP IT REAL, KEEP IT SUBARU"
Probably Vehicle Speed Sensor, although I've gotten this code stored in memory and never had an issue driveability wise. Check the codes - it's easy.
I've got a similar problem. Hopefully yours is just a cable or something like that. Maybe this thread will help you as well:
http://bbs.legacycentral.org/viewtopic.php?t=16507
δ13/12C = -17.7 ‰
δ15/14N = 9.4 ‰
δ15/14N = 9.4 ‰
