engine surge
engine surge
Hmm when i drive my car around the 4k range it like surges and it feels like it lost gas or something for like one cycle of the engine. is that just hesitation? or something else
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
When was the last time you did a tune up? Are you flooring it at 4000, or are you just modestly on your gas pedal? How full was your tank?
We need some more information
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
it does it when i floor it, tune up, hmm i changed the oil and spark plugs last month, and air filter. there was enough gas it does it when its full too. it just surges like a loss of power for one cycle. u can feel the surges. or stumble i guess
Well I would definately look at your fuel filter and see if that helps. They aren't that much money. I see you have a n/a car so there isn't much in the way of turbo problems that you could be having. I would probably check the fuel filter first and see how that helps things.
2014 Volvo S60 T5
2014 Volvo S60 T5
Mine is located under the hood just in front of the brake fluid bottle. There is one line coming into it, and one going out. It is a cylinder shaped thing next to the driver's side strut tower.
2014 Volvo S60 T5
2014 Volvo S60 T5
Maybe fuel cut? I doubt it though, maybe just hesitation.
My hesitation was caused by a bad seal around the TB. That was actually the cause for a LOT of my problems.
I'd bet fuel filter, too. Its about a 4" diam cylinder with the two lines on the top about maybe 6" high.
i dont think its the fuel filter because it still has power when i floor it. maybe its a misfire. its just annoying to have this. oh it only does it once in a while once the engine is at operating temp.
Whenever mine goes it only causes problems with off-line hesitation. I replace it about every 20K which is about how long it takes for it to give me the hesitation.
