I've been reading some stuff over at Nasioc about spherical bushings vs. polyurethane bushings and just wanted to get eveyone's take on the subject. I'd like to know what everyone is using for endlinks and how they like them. Also, what is eveyone's take on the pros/cons of each?
The most informative thread on Nasioc that I found was this:
http://forums.nasioc.com/forums/showthr ... genumber=1
-Brian
Spherical vs. Polyurethane Bushings for endlinks...
eastbaysubaru
'04 PSM FXT
eastbaysubaru
NuwanD
I don't believe so, needle bearings only allow for axial movement in a shaft, similar to a crank bearing or wheel bearing except instead of balls as bearings long thin cylinders are used which resemble needles; hence the name
A spherical bearing allows for movement in multiple axis, like the type you'd find in your tie rod ends, rotor and cuff; i guess you could say it is like your shoulder
The needle bearing endlinks I mentioned have no play in them and won't allow the sway bar to move without moving themselves, that is why they create a quicker response
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
2000 Impreza 2.5RSC (Supercharged)
1990 Rover Mini 1000
2004 Forester XT
eastbaysubaru
NuwanD
dammit, i know i've seen them before but can't seem to find them now... it may have been a custom job someone had done for a while so they may not be making them anymore?
did find the spherical bearing type however... http://hairpinracing.com/parts.htm
Nuwan
2004 Forester XT
2004 Forester XT
