Clutch change without removing engine?
NemesisEJ22t
Post by NemesisEJ22t »
I was wondering if anyone has actually done this? Everyone has been saying that it is fairly easy to remove the engine and change the clutch that way, and since i have the lift here to do this i will probably end up pulling the engine. I just wanted to hear some first hand experience of changing the clutch with the engine still in place. I get nervous at the thought of pulling the entire engine out just for a new clutch.
Ben
91 Celica All-Trac @ 0 psi (turbo being installed)
92 Celica Turbo FWD (swap) @ 12 psi HOLY CRAP!!! I miss AWD
DLC
Post by DLC »
Some do it by removing the engine, some remove the transmission...
Legacy Central
