Irregular Idle + Check Engine Light ?
BADWGN
Post by BADWGN »
yesterday after a 2km trip, i turned off the car, the turbo timer kept it going, and i went to a nearbvy shop. i heard the idle start to stutter every 2-3 seconds. when i returned to the car, it was still idling weird and i noticed the check engine light on the dash. im takin it 2 a mechanic for some testing 2day, but was wandering if any of u have had the same sort of problem ? blocked fuel line ? something cogged ? im stumped. i turned the car off and let it sit for 15 seconds, and then turned it back on, it was sweet as...
*PuZzLeD*
Cheers, Muzz
90 Legacy GT Wagon
Low, Midnight Blue on Mak Stings
MSN : muz_is@hotmail.com
If the CEL came on, check the code. Likely the idle control valve.
Post by BAC5.2 »
Yep, IAC valve. I had the same thing happen to my car. Sometimes it'd run perfectly, but then it would idle at 2k RPM's and fluctuate between 1500 and 2k. Then it would stall out and not idle at all.
I wanted it fixed ASAP so I just got a new valve for $400 from the stealership.
BADWGN
Post by BADWGN »
u guys rock, thanx for anwsering the q so fast. its going to the shop 1st thing in the morning to get the front pipe off the turbo, and the cat removed etc... 200 NZD for the work and parts = good deal.
hes gonna plug in the computer and see whats going on, but what your describing sounds like it :P
cheers all, cyaz.
90 Legacy GT Wagon
LegacyT
Post by LegacyT »
Might also be the ignition relay.
Mark,
THAWA
Post by THAWA »
why dont you pull the code?
THAWA wrote:why dont you pull the code?
BADWGN
Post by BADWGN »
Sorted man. I had the Cat removed and a nice front pipe put in place.
My mechanic fixed the IAC ? and changed the idle a little, it was high.
Cars running mint now...just got squeeky bely noise....
90 Legacy GT Wagon
How did your mechanic change the idle?
Idle on our cars isn't meant to be adjustable... a lot of mechanics don't realize that idle is computer-controlled on modern Subarus (I even had one mechanic once tell me the IAC valve was "just a sensor" and that you're supposed to adjust the throttle stop screw).
Subaru's official position is that if you move any of the screws that control throttle plate or IAC valve calibration you're supposed to replace the part.
