I've just bought a Legacy Estate 2L turbo 92 and the exhaust is wasted rather then replece it with a stadard one I thought it would be better to have a bigger one thats makes a bit more noise you know. Does anyone know if I can use an impreza exhaust as they are more common.
Legacy/impreza exhaust
yes, it will have to be custom fitted at a muffler shop, though. they will need to redo the hangers and might need to put a small extension piece before the axle back so the tip will clear the inside rear bumper.
