So besides that, is there anything else to do back there at the same time? Want to get the most for my labor fees.
Also I need to do my timing belt which I'm going to see if the shop will do since I don't feel like all that effort in my driveway. I'll flush the coolant, replace the water pump, but what else is there?
Is there anything else you could recommend replacing at 122,000 miles? I did the fuel filter, doing the air filter, valve cover gaskets and serp belts. Some of the struts are leaking, but thats not a priority at the moment.
