Where to find t-clamps?
Front, Top, Air, Water.
boostjunkie
Post by boostjunkie »
Hey guys,
I just recently started having problems with my intercooler hose coming off under full boost. No matter how hard I clamp it down it just keeps coming off under boost!!
My roommate told me about these t-clamps, that hold tighter than the standard hose clamps.
Does anyone know where to find one? Thanks!
ciper
Post by ciper »
I know what your talking about but they are NOT called T Clamps. Ill try to find the right name. I think they might be called T-Bolt Clamps.
Like this right?
edit: WOW!! READ THIS!!! http://www.autospeed.com.au/cms/article.html?&A=1596
Which hose is this? The one going to your throttle body, or coming from the compressor outlet?
I haven't heard of T-clamps before, but if the pipe has a proper bead and you put the hose on past the bead and then tighten the clamp also past the bead, any decent worm-drive hose clamp should do (maybe with a little Loctite to help). If it doesn't have a rolled bead maybe you should figure out some way to put one on...
JasonGrahn
Post by JasonGrahn »
you want these: http://www.turbohoses.com/Clamp.htm
They're expensive as hell for a full set, but well worth it.
-Jason Grahn
boostjunkie
It's actually the attachment from the compressor to the intercooler . . . on the intercooler side. It's a samco hose.
Unfortunately, the attachment on the intercooler doesn't have the little lip on it:(
Ciper, I think that's the clamp my roommate was talking about.
JasonGrahn
forget those clamps, get the ones that i showed you a picture of. They're the same style that are used with the NIRA turbo drag cars.
-Jason Grahn
boostjunkie - is it a plastic or metal tube that the Samco hoses clamp onto? If it's metal you could weld a bead down on it, or even just use a flaring tool to flare the end of the hose out a little. Maybe you could heat a flaring tool with a torch and do the same with plastic. :)
ciper
Post by ciper »
I have a wild idea, but I bet it will work great. First use some rubbing alcohol to clean the suface.
HAIR SPRAY No joke.
mTk
no title
Post by mTk »
ciper wrote:HAIR SPRAY No joke.
That'd probably work really well, used to use hairspray to keep the grips on my bike from sliding.
MK
1992 BC672 AWD 5MT
magicmike
Post by magicmike »
Sometimes people use silicone or wd40 or something to aid in getting a tight hose on. Maybe this is the case here or maybe not. The best aproach would be to clean both surfaces like you guys said but use a little soapy water. Very slippery when wet and when it dries its like it was never there. (I like the hairspray idea also but have never tried it)
Just a thought,
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
MK
Yup.....used to do that or a small shot of spray paint in the grips and then slide them on. Works great.
FG!!
Post by FG!! »
Napa has t-bolt clamps.
Get the part number off the web site before you go in.
spring loaded:
or non spring loaded:
92ss, 66bsa thunderbolt, 92miata, 06wrx
boostjunkie
Hmmm, it's actually plastic. I'll try your ideas and see what I can come up with, but I'll have to wait till the weekend to test. The last thing I need is to be driving to and from work and blow off the hose again . . . You gotta remove the whole damn intercooler to put it back on!!
I also think my DTT DC is fuxored! Now it doesn't seem to read va below .-22kpa. No vac leaks as far as I know and the engine idles smoothly.
