What should I lubricate injector orings with?
czo79
Post by czo79 »
Helloo all...
Hopefully this will be the last of my injector related inquries...my book says one should lubricate the injector orings with a light machine oil...would this be like 3 in 1 or marvel or what would people recomend?
thanks
micum
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
I'd just use whatever motor oil you're putting in the crankcase. I thought that was pretty standard. I haven't heard of using machining oil.
yup......motor oil is fine
Post by entirelyturbo »
Any rubber gasket/o-ring in the engine is probably best lubed up with motor oil. And our engines make good use of rubber gaskets.
The only gasket I can think of off the top of my head that uses something besides motor oil is the water pump gasket. That one takes RTV sealant, because it's metal...
*Formerly DerFahrer*
Well, you're not supposed to use any kind of sealant on intake manifold gaskets, I'm pretty sure. That's probably true for the throttle body gasket and the IAC valve gasket too.
czo79
Post by czo79 »
thanks guys...I called marren, the company that cleaned the injectors for me and they agreed...a light motor oil. I used an oil with a lot of conditioners for seals...figured that would work well.
thanks
micum
Micum
