Injector size
Cpt_chood
Injector size
Post by Cpt_chood »
ok i realize that this has most likely already been posted befor, but hope that no one will kill me for this.
ok i was wondering what size the injectors are for a stock 90' ej22 na are? and if i can what size injectors can i put in it with out messing around with the ECU?
thanks for any help.
I believe they flow 280cc/min at 43.4 psi.
Why would you want to put different size injectors in without messing around with the ECU?
they're 270 cc/min
You don't want to swap injectors without messing with the ecu.
Get your current ones balanced & blue printed.
