Quick answer if possible!!!
kastrix
Post by kastrix »
Hey i am leaving today on a road-trip and my A/C compressor is shot. I found a used one from a 95 legacy. the brand is the same as well as the size. My mechanic (who does not work on A/C) says all the fittings and screws are in the right place and he doesnt see why it wouldnt work.
Would this work?
@The Beast@
1992 Legacy L 5MT
Exhaust, tint, fogs, anti-snorkus, plugs, wires, rims, tires, stereo and shifter knob :-)
A good car is like a good woman...
She will turn on when you want her to and she will always give you the ride of your life.
The only issue is that, the compressor on the 95 is meant for r134a. Your compressor is probably originally for r12.
Whether that makes a hill of beans.....I really don't know. Do you have the part #'s off each compressor? I could try and cross-reference them.
kastrix
Post by kastrix »
not on me. I think for 85 bucks i'm gonna give it a try!
@The Beast@
1992 Legacy L 5MT
Post by BAC5.2 »
R12 won't work in an R134a compressor, at least I don't think it will. You'll probably have to do the full conversion.
Stick with rolling down the windows. It's more fuel efficient anyways.
avk
Post by avk »
The compressors are mechanically pretty much the same, the model is probably Calsonic V5. I believe the main reason they are labelled with refrigerant type is that they are supplied filled with a specific type of oil. Other than that, an R134 comp. should hold to R12, given that R12 systems run at somewhat lower pressures than R134. There were some R12 compressors that supposedly had seals incompatible with R134 (not on Subaru anyway), but not the other way around to my knowledge.
BAC5.2 wrote:Stick with rolling down the windows. It's more fuel efficient anyways.
This can be debated when traveling on the freeway for long distances.....
Well, it depends on how fast you're traveling... eventually you reach a speed where the increased drag of the windows being open exceeds the torque required to drive the compressor.
vrg3 wrote:Well, it depends on how fast you're traveling... eventually you reach a speed where the increased drag of the windows being open exceeds the torque required to drive the compressor.
exactly......what that speed is......couldn't tell you....
