Another timing belt question
simpreza2
Post by simpreza2 »
Im doing my girlfriends timing belt (1st timing belt change for me) and I messed up the positioning of the cyl and cams. I tool the belt off befoe taking the cam sprockets off to do the cam seals. So I rotated the cams with the crank in the same spot. How would I go about realigning everything?
Jon
2006 Outback 2.5i 5 spd- 22k
1997 Legacy Outback 5 spd- 156k
1995 Legacy L Wagon 5 spd - 226K
Just rotate the cams back to the timing marks. Very simple ;)
mTk
no title
Post by mTk »
Assuming you're GF's car is a sohc subaru, yeah, just rotate the cams/crank to the timing marks.
MK
1992 BC672 AWD 5MT
simpreza2
Post by simpreza2 »
ok I thought thats what I was supposed to do but I just wanted to make sure before I put everything back together.
Jon
THAWA
Post by THAWA »
it is a sohc right?
simpreza2
Post by simpreza2 »
THAWA wrote:it is a sohc right?
yeah
