Hey guys i wonder if this will work on our usdm they say the will work on an rs i dont know if they will work on our cars if anyone can look in to it that would be sweet
Proud owner of a 1991 Silver 5MT
Gold wrx wheels,Straight Exhaust, DNA Boost Controler 12 Psi, Ngk's, De-Snorked, Carbon fiber hood scoop in the werks
1991 White 5MT(Sold to Friend), AKA BINFORD
Looks like it would work just fine. From the picture it appears to function much the same as a boost controller, bleeding boost so that the map sensor never sees above the desired level.
The TurboSmart pneumatic FCD is either just a bleed valve or a ball-and-spring valve (or a combination of the two)... you could make the same thing yourself with like 10 bucks' worth of parts from the hardware store.
even though I don't have any need for it this idea intriques me
I assume it would be setup exactly like a mbc, where there'd be a spring with a ball one side of the parallel part of the T, and then have it inline with the map. Also a screw on top so you can set what boost the map will see. Or is there more to it?
