i did a search and didnt see anything on this
i can do both rear and front passenger at their own control fine, but the main drivers control of all 4, none of them work,
so i figured it was a power issue or something, and checked all the wiring and it looks fine,
but this is the wierd part, i have the override button that can shut off the other window buttons on each of the doors and that still works fine, i just cant up or down windows using my 4 ubtton pad.
anyone else have this problem/know the fix
thanks in advance!
power windows controls stopped working
on the inoperative window buttons, is there a definite click when pressed? If not, the plastic workings could be broken, which can't really be fixed..... I'm already on my second switch pack and its starting to go on me too....
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
