But there's a problem.
Aside from erratic boost (i.e. lots of boost creep, pulls at 9psi in 2nd, and but hits 12.5 all the way in 3rd and 4th), there is a fuel cut problem
At 12psi, in 3rd, at WOT, I get some fuel cut. If I don't go to WOT, but partial throttle it up there, it'll pull at 12.5psi no problem.
I don't think this is a problem with the FCD, but I don't know for sure.
Might this be a problem associated with the IAC code? Since it only happens at WOT. I can be boosting for a few seconds, then it'll cut, then it'll stay at WOT for a while, then cut, etc, etc. Is that overboost fuel cut? I am pretty sure I installed it correctly.
What do you guys think? If I didn't install it right, wouldn't the car run really shitty?
Stupid car
