smell gas when i floor it
91scoobiesubie
i have a turbo aoutoand i smell gas only after i floor it . why?
kastrix
Did you remove your snorkus?? Mine tends to do that too since i've pulled it. Otherwise i dunno. Try resetting your ECU. It seems as if the air to fuel ratio is wrong... I'm far from an expert tho
@The Beast@
1992 Legacy L 5MT
Exhaust, tint, fogs, anti-snorkus, plugs, wires, rims, tires, stereo and shifter knob :-)
A good car is like a good woman...
She will turn on when you want her to and she will always give you the ride of your life.
1992 Legacy L 5MT
legacy92ej22t
Does it smell like straight up gas ( as in raw fuel ) or is it just a gassy exhaust smell? You may be running real rich under WOT and have a minor exhaust leak and you're smelling that. Just an idea.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Entirely normal. I smell gas too, and I smell it in Matt's car when I ride with him. I also smell it in my neighbors 99 Taurus SHO, and in my friends Turbo Beetle.
As a saftey measure, cars run rich under WOT to prevent pinging and such. All you are smelling is unburned gas making it's way out of the car as blowby. I wouldn't worry about it unless it gets REALLY potent.
If you ever see a car get on it on the highway, you can actually see the rich exhaust.
