maf question
carl
maf question
Post by carl »
if my maf sensor is broken will it cause early fuel cut or similar problems.
if your maf sensor is broken, your car will barely run.....
Post by BAC5.2 »
10 bucks says your problem is IAC related.
You can drive the car normally, but then when you try to romp on it after driving normally for 10 to 20 minutes, you cut fuel. Am I right?
carl
Post by carl »
you are exactly right so what do i need to do
carl
Post by carl »
by the way if your right i will send you the 10bucks
