Catch Can
free5ty1e
Catch Can
Post by free5ty1e »
I'd like to re-open the discussion about what type of catch can would be required for use with our cars. Also what features to look for.
I found a rather pricey catch can here - lets use it as a starting point. Is this catch can sufficient? Does it have some feature that makes it useless in a Legacy application...? What should one expect to spend for a basic catch can that will do the job right?
http://www.subarustore.com/groilcacanve.html
...Discuss. :)
-Chris
91SS 4EAT stock, 200k mi
I don't see why any of these ridiculously expensive tanks would be any better than a little homemade one. Make a little container out of some kind of fairly inert material, fill it with stainless steel wool, and attach inlet and outlet fittings, and optionally a drain valve on the bottom.
Right?
Nigel
Post by Nigel »
Don't use PVC tubing (the black plastic tubing used for plumbing) for the can. I did, and it wasn't able to withstand the heat/chemicals. I ended up with an interesting piece of modern art!
Nigel
'94 Legacy Turbo
'73 Datsun 240ZT
Brat4by4
Stratified
Post by Brat4by4 »
http://www.clubwrx.net/forums/showthrea ... adid=54917
Very simple, all parts found within 10 feet of each other at Home Depot. About $15.
Hehehe... the picture shows him wrapping the teflon tape the wrong way around the NPT fitting. :)
That looks pretty cool. I like how it's clear so you can see how it's doing. I had a clear replaceable-element Purolator fuel filter I was gonna use at one point.
I am a little concerned about potential restrictions being added to the PCV system. I wonder if you could find a similar water separator with larger fittings so you could use 1/2" hose barbs without restriction. Those would match the size of the stock hoses.
Post by BAC5.2 »
What in the HELL is Hyundai Performance!?
free5ty1e
Post by free5ty1e »
:lol:
well its good to know that a water separator supposedly can stand the application. What might happen if one were to use this DIY catch can and, as you say, introduce a restriction to the PCV system?
We're talking about a sealed catch can here, no vents, correct?
-Chris
vrg3 wrote:Hehehe... the picture shows him wrapping the teflon tape the wrong way around the NPT fitting. :)
That's too funny....wonder if anyone told him
THAWA
Post by THAWA »
BAC5.2 wrote:What in the HELL is Hyundai Performance!?
I'm sure that's the same thing someone said when they saw i-club, or nasioc, or clubwrx for the first time.
also how are you supposed to wrap it?
Bosco
Post by Bosco »
You're supposed to wrap it so when it gets screwed in, the tape actually snugs up a little, and doesn't try to back off.
In that picture, if looking directly at the end with the threads, he should be wrapping it clockwise instead of counterclockwise...
wrapped the way he had it, the tape would tend to unwrap itself as he screws the threads in.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
THAWA
Post by THAWA »
oh okay, I thought there was some ultra secret correct way to do it :)
You can do it backwards sometimes if you're careful, but it's just easier to do it right.
