The +48 7.5" Gram Lights with 225/45/17 Azenis BARELY cleared. The tire bulged slightly past the fender and the left rear was less than 10mm away from rubbing. It was the tire width as the Azenis are the widest 225's you can buy, but it's still pretty close.
with the correct offset, and smaller 225's than azenis (if you want 225's) you should be able to shove that in there. but I wonder too why you want 8" I recall someone saying something about too big and you have less steering or handling or something, but cant find the topic.
I was thinking about wider=handling stability, kinda like that old pontiac commercial for their grand am(?) that was wider or something for better cornering, i think. Really, it was just a thought. Is an 8" (tires, kids, tires.) even beneficial on something like a WRX? the point of it was also aesthetics. I did want a tire that was wide enough that it stuck out from the fenders, so it looked tough. Kinda like phil was saying in another thread: "nothing screams "don't fuck with me" like 8.85" of rubber. (or something to that degree) Basically, i wanted a wider tire that would stick out.
91legacy_sleeper wrote:I was thinking about wider=handling stability, kinda like that old pontiac commercial for their grand am(?) that was wider or something for better cornering, i think. Really, it was just a thought. Is an 8" (tires, kids, tires.) even beneficial on something like a WRX? the point of it was also aesthetics. I did want a tire that was wide enough that it stuck out from the fenders, so it looked tough. Kinda like phil was saying in another thread: "nothing screams "don't fuck with me" like 8.85" of rubber. (or something to that degree) Basically, i wanted a wider tire that would stick out.
the main point of the wider wheel is to clear big calipers. if you want your tires to stick out I can get you a set of adj. lat. links. that will give you that "look" my car has that look. I run 225/45/17's v700 track tires that are also a very wide 225.
hmmm.. lateral links, eh? I was thinking something along the lines of H&R wheel spacers, but something tells me the name might be decieving for what i'm thinkin of.. umm.. wait until i score some wheels, unless of course you know where i could get a decent set of 16-17s? I really like the WRX stockers with RE-92s.. but, alas, i can't find 'em for less than $350 with another ~$150 in shipping.. you're only in portland, perhaps i might be taking a road trip...
