Oops, I bwoke it. (Crank position sensor)
DeusExMachina
Post by DeusExMachina »
I pulled the oil pump yesterday and couldn't get the crank angle sensor out. So, I stuck a prybar against the pump and the little bolt nub on the sensor. Pushed, and POP went the nub. :oops:
When it broke off, it took some of the casing off and exposed what was inside.
I'm asking if I should continue to use the sensor, use the sensor and seal it up (with RTV or find the nub and JB weld it on?) or buy a new sensor. A new sensor costs $200 from Subaru I think! :o
Can I use a sensor from a WRX? They're only about 20 bucks, but I'm not sure if its compatible. Help?
You could try just sealing the sensor back up and seeing if it works... I'd do it as a stopgap measure anyway.
I don't think you can use a sensor from a WRX but you should be able to contact a used parts dealer and get one off another BC/BF fairly cheaply.
Matt Monson
Post by Matt Monson »
I've probably got a used one. I can't access my FSM right now to be sure what it looks like, so if you can post a picture I can tell you if I've got it. I'll sell it for cheap if I have it...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
DeusExMachina
Sorry, I posted in the other thread asking for one that I already found one. Junkyard special.
For information's sake, its the little cylindrical sensor that is inserted into the top of the oil pump, above the crank sprocket/pulley.
