well while driving the 91 turbo tonite, i left the stop lite by wasting some fool in a riced out legacy L , anywho while i was pulling away pretty friggin hard, i noticed a pretty big smoke screen behind me,
this is the first time, at the next light i took off at "half boost" i call it half boost, (you know when your at about 1/4 throttle and the bov is half open spilling all that lovely pressure back into the intake tube) well it didnt smoke at all, only when i give it enough throttle to snap the bov shut and create boost, then she puffs away, logic tells be the oil seals in the turbo are shot, thus forcing oil into the intake, correct? or
is it internal engine components
help! thanx
rob
"granny butterin, not double slicin like you should, your lucky that 100 shot of rye didnt blow the welds on the bread lifters, now me and the mad scientist got to rip apart the crumb tray, and replace the lifter springs you fried"
