TCU question.... converted 90 tranny to '92
bretgem
Post by bretgem »
1990 Legacy wagon auto AWD. Had a 92 tranny put in along with the correct rear diff, but the mechanic forgot to put in my replacement TCU. As much my fault as his since I forgot to tell him I had one, but what do I do now? Is it something I can pop in myself? Why am I changing it in the first place (I am sure there are reasons - just curious)?
Thanks! Bret
The TCU is easy to remove and reinstall. First remove the trim panel above the driver's knees using a Phillips-head screwdriver. Then identify the TCU; it's a gold box held to the bottom of the steering column with two 10mm-head nuts. It should practically be staring you in the face. Undo the three wiring harness connections by pressing the tab on each connector while pulling it away from the TCU, and then undo the two mounting nuts with a 10mm socket on a long extension.
I forget -- it might be easier to disconnect the wiring harness connectors after the unit's unmounted.
I don't know how much it matters which TCU you use... Does it not drive well? I guess a different final drive ratio could adversely affect the shift points.
I remember ciper once saying he'd interchanged lots of different TCUs successfully, including putting one for a 95 Impreza into a 90ish Legacy.
Anyway, if you have the 92 one maybe you should just try both and see which works better.
bretgem
Post by bretgem »
thanks guys - when I posted this I had hoped somehow I might be able to get a diagram - - so the excellent description and the picture helped a ton - - I'll let you know if i run into any problems and need further help.
Bret
bretgem
this was wayyy to easy
Post by bretgem »
Thanks again - went in nicely.... took all of four minutes, but then i lost most of the screws for the panel, so my total time increased to about fourteen as a result. Thanks for saving me another trip to the mechanic!
Cool.
Lots of us don't even know where that panel is anymore... I took mine out the day I got the car and have kept it out ever since. :)
kpurcell
Post by kpurcell »
Just curious, did the TCU swap make a difference.
I recently changed tranny/diff from 3.9 to 4.11 (auto tranny)
Does the TCU car that my ratios are different?
Anyone else w/ TCU experience (preferably on automatic) ?
