do rear AWD springs work on FWD cars?
greg donovan
Post by greg donovan »
i know i may need to change my upper mounts on the rear since i have the old tapered rear springs on my 90 sedan.
so, the question is can i use AWD springs on the rear of my sedan?
the GC chassis RS springs look they would be a nice match for the GR-2 and a sway bar upgrade. my current spring rates are a pathetic 123 front and 129 rear. if AWD stuff works the GC RS has 157 front and 149 rear.
thanks again for the suspension sticky data!
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
they should fit....as long as you have proper top mounts for springs they should work. Not sure how the ride height will be though.
greg donovan
the rear awd struts are shorter than the FWD ones, arent they?
but the perch is in the same spot with respect to the body, i think.
96 Impreza L sedan
00 Impreza RS sedan
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
i dont think it'll fit
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
greg donovan
LaureltheQueen wrote:i dont think it'll fit
do you mean the struts wont fit? i know that.
or do you mean the springs wont fit? that i dont know.
what i was getting at is the perch on a awd strut the same distance from the top as it is on a FWD rear strut?
the perch would then be closer to the bottom on the awd strut than on the fwd strut.
96 Impreza L sedan
00 Impreza RS sedan
scottzg
Post by scottzg »
I have rs springs and shocks on my 90, i had to replace the rear top mounts and the front spring perches
greg donovan
scottzg wrote:I have rs springs and shocks on my 90, i had to replace the rear top mounts and the front spring perches
but mine is FWD.
you had to change the perches on the strut?
96 Impreza L sedan
00 Impreza RS sedan
scottzg
Post by scottzg »
i think the 90 awd and fwd strut set ups were the same. Don't quote me.
Yup, that came as a surprise.
LOOK....struts are different.....springs I think you can change without too much issues as long as the top mount is the same.
I got my car done today, and ride height is pretty much identical to what is was before. Granted I have aftermarket springs....so that may not be an accurate comparison.
greg donovan
i think the front struts may be the same but the rears are different i am talking about using awd rear springs on the rear struts of a fwd car.
96 Impreza L sedan
00 Impreza RS sedan
Just to let you know.....I put the FWD rear end on the donor legacy today.
AWD struts will NOT bolt up to the FWD rear hubs. However FWD rear springs WILL fit on FWD rear struts.
Ride height looks ok.....
scottzg
Post by scottzg »
Legacy777 wrote: However FWD rear struts WILL fit on FWD rear struts.
How's that work again?
greg donovan
Legacy777 wrote:Just to let you know.....I put the FWD rear end on the donor legacy today.
AWD struts will NOT bolt up to the FWD rear hubs. However FWD rear struts WILL fit on FWD rear struts.
huh?
i know that the FWD rear strut bolts in the place where the rear halfshaft lives on the AWD rear hub.
are you trying to say that the rear FWD springs work on the rear AWD struts?
96 Impreza L sedan
00 Impreza RS sedan
sorry.....brain fart when I originally typed the message.
I edited it. I was trying to say you can't put AWD rear struts on FWD rear hubs.
And that AWD rear springs work on FWD rear struts.
greg donovan
cool.
so the FWD rear struts are longer? yet the perch is in the same relative position as on the AWD rear?
that means my spring options arent as limited as i feared.
96 Impreza L sedan
00 Impreza RS sedan
yeah they're going to be longer, but that's not why they didn't fit. The bottom housing is different and won't clear how the fwd rear hub is setup.
