Which ball joint will fit??
ej22t
Post by ej22t »
Hi people, just has a questions for help, I got an aluminum front lower control arm from an GC WRX and I would like to install it this morning, after I remove the old steele control arm, I just found out that the ball joint bolt are too small to the Aluminum Control arm.
Does anyone know which ball joint will fit with this control arm???
Thanks for help.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
