I'm doing the timing belt and crackcase seals today and some other little things $$$ 100.00 for the timing belt? $20 for all the little seals.
Also removed the interior trim pieces cause the guy before me had painted the console and everything else siver I'm changing it to black.. I'm going to remove the seats and carpet today make sure the floor is rust free and shampoo and patch a hole in the carpet..
After All that I think I'm going to replace all my axles one at a time and wheel bearings. I also have to replace my control arms.
What else should I look into replacing suspension wise??? Does this car have rear control arms?? Do you guys replace anything with urathane bushings?
My shocks and springs have to be replaced but not this year.. What a good set up for this car. Can I run H&R springs??
Anything in the driveshaft that goes?? I'm going to buy a set of BBS CH rims next summer..
Also I've sanded down all the rust spots on the car and I'm going to use POR15 then prime and paint.. But I would like to do a nice paint job in the future.
I guess that covers most of it.. Going to spend lots of $$ but it worth it this car and I got it for cheap..
You guys have any input.??
