Thoughts on my Turbo Upgrades
Paisan
Post by Paisan »
113K miles on my '94 Legacy Sedan Turbo
I'm planning on putting on the following and would like to hear from some folks more knowledgeable than I on the viability or if you think I'll need anything else...
VF23 Turbo
V4 STi Intercooler
Bosal Downpipe
Custom DP back exhaust
VDO EGT, Boost, Oil Temp, Oil Pressure Gauges
MBC
There has been debate if I need to add in some kind of engine management such as a SAFCII or similar. What kind of reliable power do you think this setup will yield?
I've already done the suspension, tires and brake upgrades which I always believe in doing before adding power.
-mike
Post by BAC5.2 »
Sounds like a good idea. If you want to make a lot of power (or have the potential to), you should ditch the TMIC and go FMIC.
Get a good downpipe (CES for example), and that's about it.
You could safely make about 260 or so on the stock fuel system (in terms of total flow of the stock injectors).
What color is your car, by the way?
Paisan
Post by Paisan »
Nah no FMIC for me, hate lag-mounts... :)
Also don't want to go too crazy i figure about 250 at the crank will be fine for me.
http://azpinstalls.com/miscpics/azp-05-15-04/index.html
Mine is maroon, pics in the link above :)
-mike
legacy92ej22t
Post by legacy92ej22t »
Mmm, nice ride! Looks very good. :)
You're mod list sounds nice but if all you're looking for is 250 chp then IMO the VF23 is a bit of an overkill. You could achieve 250 chp with a TD04L out of a rex and get it for probably around a $100. Not only that but it'd most likely have really low miles on it.
You can actually achieve around 250 chp on the VF11 too but you'll have no high end. The VF11 can't hold more then 10-11 psi after 4800 rpm.
IMO, you're fine with stock engine management at 250 chp but you may (should) want to add a Walbro 255 FP to that list.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Paisan
Post by Paisan »
Well I have the VF23 already got it cheap and low miles. I have a TD04 around too so I might use one of them.
Fuel Pump is easy to drop in, not a problem.
I figure 250-280, it is my daily driver so I don't want to totally kill my gas milage. :)
-mike
heelhooker
Post by heelhooker »
for what it's worth...
stock injectors: 330cc/min
LHV gasoline: 44 MJ/kg
density gasoline: 780 kg/m^3
assume fuel conversion efficiency of .3
max mass flow rate fuel= (330)*(4)*(1/60)*(1/1000000)*(780)=0.017 kg/s
power=efficiency*LHV(fuel)*flow rate(fuel)=(0.3)*(44000)*(0.017)
=227kW
=304 hp
now, is that 330cc/min at 100% duty cycle? if so, I guess 300 hp would not be "safe" on the stock system. Is a 30% fuel conversion efficiency a reasonably assumption for this engine? I would guess it's in the ballpark.
1991 ss 5mt ej20g (sold)
1988 mazda 323 gtx
2005 EVO RS
legacy92ej22t
Aren't our stock injectors 380cc?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
rsstiboy
Post by rsstiboy »
Paisan wrote:Nah no FMIC for me, hate lag-mounts... :)
-mike
pfft, i get no lag, plus I'd rather have a intercooler than a interheater.
1) I don't believe that front-mounts are inherently laggy. The volume contained in any decent intercooler piping should be easily consumed by the engine in a small number of revolutions.
Of course, there are a lot of people out there without decent intercooler piping. Too many bends -- especially if they're not mandrel bends -- hurt flow. So do transitions between pipe and hose. If pipe is welded together from short pieces, it can be hard to avoid ending up with jags from the welds coming through the surface of the pipe and interfering with airflow.
2) I'd say turbocharged engines on boost are a good deal less efficient than 30%.
3) The stock injectors flow around 370cc according to the flow tests RC Engineering did for magnux, at 100% duty cycle.
Paisan
Post by Paisan »
I also don't want to hack apart my car... So lets stick with TMICs that can be put in with my AC working for this discussion :)
-mike
'04 Nissan Armada
'94 Subaru Legacy Turbo 5MT Sedan Race Car
'05 Subaru Legacy Wagon 5MT
http://TeamIAC.com
http://AZPInstalls.com
heelhooker
If stock injectors flow 370 cc/min at 100%, then 0.017 kg/s flow rate seems reasonable.
As long as fuel enrichment is not the main charge cooling mechanism (good intercooling, water injection, etc), and timing isn't backed off too much, efficiency at max output will be close to that of a n/a engine. I don't think ~30% is unrealistic based on literature I've seen. If charge temp is high, and timing is backed off due to knocking, of course efficiency will suffer.
Anyway, I plan to find out...
1988 mazda 323 gtx
2005 EVO RS
Paisan
Post by Paisan »
Cool a good friend sells water injection kits :)
-mike
'04 Nissan Armada
http://TeamIAC.com
shemoves
Post by shemoves »
Just reading through this searching for some answers and figured it was better to post in an old thread than start a new one.
Regarding the stock injectors, what is the most boost you would run a 16g with them-assuming most of the other related parts(walbro/em/fcd/IC) were upgraded.
Adam West
Post by Adam West »
Yeah, I'd like to know that too.
To the list...yes, FCD I've heard is a must.
But I'm still in the planning stage too.
Any consensus on clipped wheels? Thinking of adding that to my deadbolt order...
Splinter
Post by Splinter »
hate to drag this offtopic, but arent gasoline engines below 50% efficient?
I remember reading something about how almost half the power the engine makes is lost in the exhaust heat
Splinter
Post by Splinter »
Adam West wrote:Any consensus on clipped wheels? Thinking of adding that to my deadbolt order...
Clipped wheels = sacrificing bottom end for top end.
I wouldnt bother unless you are planning on rebuilding the valvetrain for a higher redline
Adam West
Post by Adam West »
Hmmm. Is that the same as lowring spool time, i.e. time to boost aka turbo lag? I thought that was the beni of clipping wheels? And if that was true then you'd be sacreficing top end for bottom end. What think?
This is one of those common internet folklore things.
If you want to know the real scoop talk to a vendor or shop that deals with turbos a lot. Deadbolt would qualify as one of those shops.
The main thing clipping helps with is overboost at higher rpms. Depending on the setup, it can also aid in spool up by allowing the engine to breathe with less restriction.
Like I said, if you have questions, call and talk with Jerry.
