This is from my MY00 2.5RS. I lke to say that my torque curve is as flat as a high school gymnast!!! This dyno was done at 5000ft in SLC on the same dyno that Cobb uses. A stock EJ25 powered 2.5RS gets 122.5 whp and a stock Ej20 powered WRX gets 169.9whp on this same dyno. Based on that and a little math, I am probably making 205-210hp at the crank.
My mods are as follows:
Cobb CAI
Cobb equal length headers w/high flow cat
Stromung 2.25" TT cat back
Unorthodox Racing underdriven and lightened crank pulley
NKG Platinum plugs of stock heat rating
Walbro 255 fuel pump
Cobb Club Racer aka "spicy" cams
NO engine management!!!
Other mods:
STi v5 inverted struts on stock springs
11.4" cyro treated rotors
Cobb SS brake lines all around w/Cobb Pads and Blue racing fluid
Cusco adjustable rear sway bar
STi front strut tower bar
Helix solid end links with spherical bearings all around
That's about it. I just thought I would throw this out there since I don't really talk about this car that much around here. And here are a few shots from the last CO rally-x where I placed 8 of 16 in open class and 15th overall of 43 entrants. Not bad for my first day running in the dirt.
