HELP... again
jake15
HELP... again
Post by jake15 »
well.... i thought i had my car fixed.... but no. i found the cam sensor plug unplugged so i plugged it back in and put it back together, now it starts and then dies. it has weak spark and no codes, thats whats getting me its like it starts then something just stops arriving (fuel, spark, etc) and it just dies. this car is out to get me :evil:
Can you make it keep running with the throttle?
jake15
Post by jake15 »
nope
Hmm.
Your car ran before, right?
Is it possible you have a big vacuum leak?
jake15
Post by jake15 »
i dont know if it does have a vacuum leak. it did run before, i went to lunch, came back and it would not start. i did run it with the bov venting to atmosphere at idle..... but just for a couple parking lot passes.
Hm.
You have access to a Select Monitor, right? Maybe you should see what the various readings look like right as it stalls.
JasonGrahn
Post by JasonGrahn »
why not get dad or brother to fix it?
Make sure your brother doesn't forget to tighten the shift linkage in your car so that the bolt nearly-almost falls out completely and leave the shifter sloppier then a 50 year old hooker on the bad side of the tracks like he did with mine.
-Jason Grahn
jake15
Post by jake15 »
vrg3- i'll do that when i go back 2 the shop, thanks\
jasongrahn- i'm sensing some hostility on your part.... i wouldnt have to worry about that cuz i put the transmission in... and its an automatic :( no 5spd yet
JasonGrahn
no worries so far, i've fixed it. :D
-Jason Grahn
jake15
Post by jake15 »
thats kool :D
jake15
Post by jake15 »
well i havent been to the shop much with school being started and all.... but i did get my hands on a bov, a turboxs type h, which hopefully i will put on within the next week, then well see whats going on from there.
