water pump replacement
Posted: Thu Sep 23, 2004 5:09 pm
by 91scoobiesubie
when replacing the water pump must you remove timing belt and what is the easyiest wayy to get the pulley off and easiest way to accoplish this task?
Posted: Thu Sep 23, 2004 5:55 pm
by WRXdan
Yes the timing belt needs to come off. The pulley bolt can be a bear to remove. If you car is MT then stick the trans in 5th, pull the ebrake and have some one hold press the brakes while you remove the bolt. You will need a 22MM socket plus a breaker bar and a long handle extenion. I had a 4 foot one and still had to put all my weight on it. If it's auto then you need to lock the crank or buy subaru's tool to remove the pulley. You can "lock" the crank by inserting a screw driver into the whole that access the torque converter bolts or somehow lock one of the cam pulley. I don't recommend either method.
Posted: Thu Sep 23, 2004 6:08 pm
by greg donovan
i have done the scredriver method. works just fine. but you need help. the teeth are very strong.
Posted: Thu Sep 23, 2004 6:11 pm
Use a round breaker bar to stick in the access panel. It works fine, and I've done it several times by myself.
Posted: Thu Sep 23, 2004 7:18 pm
by 91scoobiesubie
are you guys describing how to get the crank shaft pulley off? if not how do you get that off?
Posted: Thu Sep 23, 2004 7:28 pm
by WRXdan
91scoobiesubie wrote:are you guys describing how to get the crank shaft pulley off? if not how do you get that off?
Yes, once you have the bolt out, use a puller or just slowly "walk" the pulley off the crank nose.
Posted: Thu Sep 23, 2004 7:37 pm
by 91scoobiesubie
what do i need to now about removing the belt itself? thanks for the help
Posted: Thu Sep 23, 2004 7:51 pm
Posted: Fri Sep 24, 2004 1:53 am
by 91scoobiesubie
the timing belt was replaced 6000 miles ago. there was no coolant leakind near the timing belt just driping at the bottom of the pump. since i am takeing the belt off must it be replaced?
Posted: Fri Sep 24, 2004 3:30 am
by douglas vincent
In a short answer. No. If it aint broke, dont fix it. I have taken mine off and on about 4 plus times now in the last 5-6 k miles.
Posted: Fri Sep 24, 2004 7:10 am
by evolutionmovement
Pull the engine and use an impact gun :)
I brace the pulley with a strap wrench against the immortal alternator pulley.
Posted: Fri Sep 24, 2004 10:40 pm
by 91scoobiesubie
first time doing this and last. car wont start i think i f@#% up the timing can i fix it or should i take it to the dealer?
Posted: Sat Sep 25, 2004 2:41 am
by 91scoobiesubie
are the cam sprakets and crank all marked? if so all i need to do is line the lines from the belt with those marks?
Posted: Mon Sep 27, 2004 4:07 pm
91scoobiesubie wrote:are the cam sprakets and crank all marked? if so all i need to do is line the lines from the belt with those marks?
yeah everything's marked.
You can see some pics of the marks in these pics
http://www.main.experiencetherave.com:8 ... injectors/
