water pump replacement
91scoobiesubie
when replacing the water pump must you remove timing belt and what is the easyiest wayy to get the pulley off and easiest way to accoplish this task?
Yes the timing belt needs to come off. The pulley bolt can be a bear to remove. If you car is MT then stick the trans in 5th, pull the ebrake and have some one hold press the brakes while you remove the bolt. You will need a 22MM socket plus a breaker bar and a long handle extenion. I had a 4 foot one and still had to put all my weight on it. If it's auto then you need to lock the crank or buy subaru's tool to remove the pulley. You can "lock" the crank by inserting a screw driver into the whole that access the torque converter bolts or somehow lock one of the cam pulley. I don't recommend either method.
92 Turbo Legacy 4EAT
02 WRX - lightly modded (Gone but not forgotten)
greg donovan
Use a round breaker bar to stick in the access panel. It works fine, and I've done it several times by myself.
91scoobiesubie
91scoobiesubie
http://www.main.experiencetherave.com:8 ... _belt1.jpg
http://www.main.experiencetherave.com:8 ... _belt2.jpg
http://www.main.experiencetherave.com:8 ... _belt3.jpg
http://www.main.experiencetherave.com:8 ... _belt4.jpg
http://www.main.experiencetherave.com:8 ... _belt5.jpg
http://www.main.experiencetherave.com:8 ... _belt6.jpg
http://www.main.experiencetherave.com:8 ... _belt7.jpg
http://www.main.experiencetherave.com:8 ... _belt8.jpg
91scoobiesubie
douglas vincent
In a short answer. No. If it aint broke, dont fix it. I have taken mine off and on about 4 plus times now in the last 5-6 k miles.
Pull the engine and use an impact gun
I brace the pulley with a strap wrench against the immortal alternator pulley.
91scoobiesubie
91scoobiesubie
yeah everything's marked.91scoobiesubie wrote:are the cam sprakets and crank all marked? if so all i need to do is line the lines from the belt with those marks?
You can see some pics of the marks in these pics
http://www.main.experiencetherave.com:8 ... injectors/
